One of them goes to a fitting on the compressor's outlet for pressure. The other would go to the fitting on top of the plenum just before compressor inlet for vacuum. I highly recommend not connecting this hose and just cap off the plenum fitting.
I believe it is the rear fitting that goes to the inake manifold (pressure). Make sure the wastegate actuator is not leaking internally.
