I run my gaps at 30 or 32 on some Delco CR42TS.
As for fuel, I run an Oddfire snout cam, which allows me to use a High Volume 455 mechnical fuel pump. ive never had a fuel issue other than a destroyed cam bearing. but a set of the HD TA's solves that.
As for pump, the stock electric in tank or even the stock mechanical is plenty enough fuel for most of the carb turbos. as the stock Q-jet has a fairly large fuel resivour and large needle and seat for high volume. once you start pushing the 400 HP limit or are doing something other than straight line action, then i would suggest moving up to even a mild holley blue or red pump.
again here, unlike the SFI guys, were more concerned with volume than pressure here so we dont need a crazy insane pump system to keep up with them.
as for intake.... 55 bucks shipped.
no you cannot use an intercooler with the turbo you have.
A.j.
