'83 Regal T-type trunk torsion bars
84ZZ4
Hi all,
I'm working on fixing up my '83 Regal T-type. My next job was going to be to replace the trunk torsion bars (the trunk doesn't stay up). I have one of the original bars, and I pulled a set off an '84 4 door Cutlass that I junked, but they don't fit. The "U" end of the bar isn't wide enough. What gives? I need to know what car to pull some bars off that will fit, or what other options I have. Here's a pic of both bars, the narrow gray one is the Cutlass bar, the wider black one is the Buick bar.
If the original bars are in one piece they should be adjustable using the notches where they hook in.
4 door bars are different. Any G-body coupe is what you need. Most of the pre-1982's used the gas struts instead of the torsion bars.
One of the original bars is missing and has been since I bought the car. Considering I got it for a song, I can't complain.
Turbofish, thanks, glad to hear it's only a 2dr/4dr thing. I shouldn't have too much trouble finding replacements then.
How does one go about agjusting these things? They have a ton of force on them already. Anyone done this without breaking something or someone?
GM has a special tool that works good, other than that, channel locks and luck :eek:
