83 T Type CE Light came loose!
Anyone know where this wire connects to coming off the bulb? I removed the dash and now my light does not work. I noticed I have a bulb with pink/blk and yellow wire. The yellow wire came disconnect and I have no idea where to connect it back to. Will this effect my scanmaster? Will I still get the MAL code?
Check the ALDL connector under the dash. I don't have a wiring diagram for the `83 but your loose wire could be from the B terminal.
The ALDL connector looks like this:
Here's some more information on the service light and trouble codes for early GM computer cars:
Buick Trouble Codes or Buick Service Engine Soon Codes at TriShield.com The Buick Enthusiast Network
Good luck, Jimmy
Appreciate it! It ended up being the third port from the left as looking at the photo. Mine was a yellow wire on the port too. Previous owner must have pushed the bare yellow wire into the yellow wire port. Everything working again. I ended up re-wiring everything since it looked like a cluster bomb went off under my dash. Thanks again!
