84-87 Buick Regal Grand National Turbo Fuel Gas Tank GM307C Spectra
Turbwo
Brand New Reproduction Fuel Tank
Canadian Made Tank
17 Gallon Capacity
Metal Pan / Baffles in Tank
Since the turbo models have an electric fuel pump, the O.E.M. factory tank had plastic baffling inside to help control the gas from sloshing around. This tank has metal baffles welded in place to achieve the same purpose. Please do not confuse this tank with a Non-Turbo tank even though they "look" the same.
Dimensions: 36 1/4" x 24 1/4" x 8 7/8"
This tank is stamped from high-quality automotive grade steel with a natural finish
O.E.M. Approved Ni Terne Steel
Corrosion Resistant
Each tank is pressure tested twice underwater for quality before it leaves the manufacturing plant.
Gasket and Locking Ring for the fuel sending unit are included
Straps are sold separately
Fits:
1984 - 1987 Buick:
Regal Turbo Charged Models
Grand National / GNX / T-Type / T
Located in Allentown, Pa
$130.00 pick up or you arrange shipping. It's considered over-sized, so shipping might be pricey.
Box size: 38 x 32 x 15
Weight 42lbs.
