In the middle of a frame off restoration / to my 84 T-Type and figured I would check bearings on the motor - can't find torque specs for an 84 but the 86/87 is posted everywhere and hoping the torque spec's are the same (100ftlb crank / 40ftlb rods) - would make sense but I figured I better confirm. Turns out the motor was a reman - .020 over pistons, .030 over rods, .020 over crank bearings
- probably good for a daily driver but was hoping to convert to E85 and turn up the heat. If someone could confirm the same torque specs apply between years that would be really helpful so I can get this one back together. If anyone knows of a short block / engine lead please point me that way - so many decisions to make now .........stay Hot air - convert to inter-cooled if I could find a complete set-up - want to keep the car all Buick - Thanks Much!!
