84 grand nat
mr84ss
Whats up fam. I want to buy a 84 grand mat and the owner said the oil pump gears bad. Have anybody ever heard of this problem and how hard is it to fix. Thanks in advance
If it's not pumping oil then it may have killed the engine. Depending on how much he wants it may or may not be worth it. Go to your user controls and add a location and check out your state section to see if some one will go with you to check the car out. This will save you more headaches later.
