84 HA engine/transmission with 87 intake
I have an engine out of an 84 grand national (hot air) that i need to get rid of. the ecu/wiring harness come with it too
the engine has less than 3000 miles on it, and ran when we pulled it.
the headers were cracked, but they have been TIG welded/reinforced since then. they aren't attached, but i do have new gaskets for them.
i have the downpipe too, but one of the bolts is sheared off on the turbo, an easy fix.
i also have the intake manifolds (upper/lower), fuel rail, throttle body, injectors off of an 87 grand national (an intercooled model) that ill throw in if you take it all for 1000$
