next_level
- Jan 29, 2002
when using an 85 block in a 87 what is the procedure....are the crank/cam sensors the same? i know you need to tap a hole in the pan for a return line from the turbo...is that all...
SignUp Now!BigDaddy said:...but 84/85's had a different crank sensor, I'm assuming that you are using an 86/87 wiring harness so you would have to change the sensor...
