86/87 engine complete/running
NOKA72
Looking for an intercooled engine complete and running ready to drop in and go..would like to hear it...so if your closer to ny 11228 that would be great...lmk vinny
pics to....
noka72@aol.com
$2500 complete with everything . 80,000 mile unopened engine is what i was told.come go for a ride then we can pull it out won't take long
Vinnie- did you ever find the chrome bumper you were looking for? I have a friend in Brooklyn that has a nice one 4/sale off his show car-Matt 347-680-8642.
501whp. Bowl blended iron heads with ports squared up and matching intake. Ported ex manifolds, 212-212/.497 gross lift, T&D's, 70 mm TB. 6176 Turbo and Precision fmic included. Engine management not included. Alky injecton not included. AC components not included. Only thing you will need to do is figure out what you want for an ecu and get an AC compressor and lines(or go AC delete) and get a PAC alky kit. $6800. Come to CT and experience it. I can drop it into your car and guarantee the same whp for $7600 if you provide the AC and ecu and alky injeciton. Ill do it for $8800 if i provide a stock harness, ecu/ TT chip (including 3.5" MAF w/ translator), and alky injection. If you want it freshened ill take care of that for another $600. Ill do a trans and a 9.5" PTC converter for another $2500 outright that way you will have a trans that wont fail under the power too.
THNX BISON...SOUNDS GOOD...JUST A TAD TO XPENSIVE:wink:THNX AGAIN BUD..VINNY
Its actually a great deal when comparing it to what it woudl take to duplicate it. It would take most at least another $7k to get similar performance. Seen several cars come through here in the last few months with $15-20k invested and still have stock trans internals, stock ecu, zero suspension work, barely making 500hp and running 11's:rolleyes:. I love it when i see a low 11 sec car that has heads, cam, "built" short block, a turbo capable of supporting 850hp and it makes a whopping 500hp. Its funny to see peoples reactions when they see how poor their actual hp really is. Im often asked what i think it will do and am usually within 5%. So i write that number down and show them after the dyno pulls. Typically the owner thinks they have about 75 more hp than they really do. The truth is most should have about 125hp more than they do for the parts they have on them. I could do a stock long block installed for $3200 not including AC lines/compressor.
Do you have that stock long or short block to sell outright...vinny
I dont sell anything mechanical used for over $500 unless its been run by me in one of my cars or unless the buyer wants to sign that it was sold in "as is" condition or i install it myself. I would never sell a stock long block with the stock timing set in it either. Ive seen enough instances in the last 6 mos. Where used parts are installed and there is a problem that resulted in lost time and wasted labor as well as costs to repair. Let me know exactly what you are looking for. Harness yes or no, AC components yes or know, down pipe and hardware, yes or no.
Im looking for something complete to drop in and go as my engine is apart for a rebuild and im tired of the car sitting...tb to oil pan..flywheel to balancer....in good running condition is what im searching for a no issue decent runner...vinny
Still looking....also..looking for a rebuildable short block////std only please....also have stuff to trade.....lmk vinny
