86/87 GN Drivetrain Parts F/S
Vsix
Stock D-5 convertor 130k miles $50
2- Cooling fans $60 each
2-GN ECMS $60 each
Stock valve covers $40 pair
2-Hard cooling lines $40 each
Pair of coil & ign brackets (flat & U shaped) $65 pair
Main alum acc bracket $65
Tensioner $65
Oil drain line & nut (goes into the block) $45
Stock turbo elbow $30
Stock Fuel rail $45
2-Stock up-pipes $30 each
2-Throttle brackets $40 each
Stock lower intake manifold $175
Throttle cable $40
Water pump pulley $25
Alternator $40
Balancer $60
Stock pass side header $60
Oil dipstick & tube $30
Intercooler fan $30
Stock turbo cover (uncut) $40
Hard fuel lines from the frame to eng feed & return $60
Stock turbo complete ready to bolt on low miles $200
Upper intake (doghouse) $40
Stock throttle body & upper intake $80
2-Sets of AC lines $50 each
AC compressor $50
All parts are plus shipping ...Sorry no pics ...
Thanks Jim
215-669-1696
Cooling fan $60
2-GN ECMS $60 each
Tensioner $65
Stock Fuel rail $45
Throttle cable $40
Alternator $40
Balancer $60
87 GN gas tank $60 (local pickup only)
Intercooler fan $30
AC compressor $50
87 GN engine wiring harness needs some repair but worked $100
UPDATED LIST !!!!
Cooling fan $60
2-GN ECMS $60 each
Tensioner $65
Stock Fuel rail $45
Throttle cable $40
Alternator $40
Balancer $60
Intercooler fan $30
AC compressor $50
Turbo AC box upper & lower with metal cover and NEW heater core $150
UPDATED LIST !!!!
Cooling fan $60
2-GN ECMS $60 each
Tensioner $65
Stock Fuel rail $45
Throttle cable $40
Alternator $40
Balancer $60
Intercooler fan $30
AC compressor $50
Stock GN trans crossmember $30
UPDATED LIST !!!!
Cooling fan $60
2-GN ECMS $60 each
Tensioner $65
Stock Fuel rail $45
Throttle cable $40
Alternator $40
Balancer $60
87 GN gas tank $60
Intercooler fan $30
AC compressor $50
UPDATED LIST!!!!!!
Cooling fan $60
GN ECM $60
Tensioner $65
Stock Fuel rail $45
Throttle cable $40
Alternator $40
Balancer $60
87 GN gas tank $60
Intercooler fan $30
AC compressor $50
UPDATED LIST!!!!!!
Cooling fan $60
GN ECM $60
Stock 87 up-pipe $30
Tensioner $65
Oil drain line & nut (goes into the block) $40
Stock turbo elbow $25
Stock Fuel rail $40
Throttle cable $40
Water pump pulley $20
Balancer $60
Stock pass side header $50
87 GN gas tank $50
Intercooler fan $30
Upper intake (doghouse) $35
Stock throttle body & upper intake $75
AC compressor $50
UPDATED LIST!!!!!! NEW PRICES TOO !!!
wiring harness
What repairs does wiring harness need? Is it still available? Can you send a photo?
Cooling fan $60
Tensioner $65
Stock Fuel rail $40
Balancer $60
87 GN gas tank $50
Intercooler fan $30
NEW GN heater core $30
Cooling fan $60
Tensioner $65
Stock Fuel rail $40
Balancer $60
87 GN gas tank $50
Intercooler fan $30
Pics of parts...............
gn parts
Interested in oil dipstick and tube,Throttle bracket, electonic egr thing. Do you have flat plate that screws to bottom of coil back also. Thanks
87 TR gas tank .....
parts
Hello I need the main accy bracket and tensioner, is pay pal ok and how much shipped to 98661. Thanks.
