87-86 GN Parts (Spring cleaning)
V8killR4U
All prices are OBO and do not include shipping. I do take PAYPAL but you have to pay the additional 3% fee. Just doing some spring cleaning. Thanks
Fuel Rail: $35
Oil Pump gear: make offer
Turbo Tweak alchy chip: $30 (42 lb injector, for 23-25 psi,version 5.2)
Cam gear: make offer
Double roller timing chain: make offer (never used, not sure of brand, says Rolan on the links)
Dual Pod A Pillar Holder:$25 (Has small piece broken at the bottom, glue the pice back on and paint and its good as new, or just throw it on as is)
Breathers: $10 for both (One is a K&N and the other is a Murrays breather)
Push rods: $45 (8.350 .80 These are in good shape, was used on my roller set up with T&D rockers and GN1 heads)
Water Pump Pulley: Make offer
(3) GN badges: $30 for all (condition 6 out of 10)
Fuel Pump Hanger: $45
(2) Cam Sensors: $65, $50 (Both work, one has a crack on the side of the cap)
MSD 8.5mm wires: $35 (Work fine, just need to be cleaned up)
(6) Clamps: $10
Newer REDS XP Pump and hanger: $125 (Just pulled this out of my car and replace with a REDS DP, pump works fine and has low miles, not sure on exact miles, actually have the receipt for this some where)
(2) REDS XP Pumps: $50 ea. (I received when when i bought a hanger and the other I had in my car because i thought my pump as bad turned out to be a kinked line by the filter. Both pumps work fine)
I will take it, PM payment info
Thanks!
fuel sending unit
I'm interested in the fuel sending unit with out the fuel pump. u call it the fuel pump hanger. Can you check it to make sure the fuel level works? Measure the resistance between the signal wire and ground, should be between 0 and 90 OHMs with out going open when you move the float.
I'll check that and get back with you in a few days.
The did work properly when it came out of my car being used with one of the other pumps I have for sale on here. I'll check it tho.
Clamps and MSD wires (SOLD)
Badges (Pending)
Breathers (Pending)
Reds XP Pumps (2) and Red XP pump & Hanger (Pending)
I have two sets of injector harnesses and another set of MSD wires in good shape.
XP pumps and hanger sold
clamps and 1 set of msd wires sold.
Taking offers on the remaining stuff. Thanks
hey,my sat net is out cause of the weather here..will send papal tomorrow..(I'm on my droid).....thanks
need fuel pump hanger
I need fuel pump hanger please contact Clif8564706465.
