buick87231
- Jan 16, 2010
its a t top car. the motor is a stock bore 231 roller motor . the heads are the best flowing you can get. 67 mm turbo
trans 400 turbo 9'' 3000- 3200 stall converter
4'' drive shaft
373 gears
eaton posi
moser axles 3'' studs
15x8 weld racing pro star wheels all the way arround
s10 wheel cylanders
drilled rotors
f650 intercooler cut to fit
progressive alchol control system
ls1 massair with translator
egt recorder
scat pro racing seats
new carpet
scan master
mallory fi external fuel pump
braded steel fuel lines
braded steel trans lines
boost guage
knock guage
trans temp guage
fuel press guage
volts guage
oil press guage
5'' monster tac
over 20k invested any questions call 703-881-1024
willing to trade for a dodge 12v manual trans
email dbs330@aol.com
4'' drive shaft
373 gears
eaton posi
s10 wheel cylanders
drilled rotors
egt recorder
new carpet
scan master
boost guage
knock guage
trans temp guage
fuel press guage
volts guage
oil press guage
5'' monster tac
