I've owned this beast since 2000. Never caged it. Car went 9.89 when last raced. Xfi controlled
30 over diamond pistons
Eagle crank internal balanced @50%
Rods are longer carrillo
Cams a comp 224/224
Heads r stock ported polished and flow great.
Transmission done by Janis trans with all the hard parts plus a bat break.
Eaton center with 31 spline mosser
Axel tubes welded
Dennys steel drive shaft with bilet yokes
Motor mounts are hr parts urethane
Lower upper control arms are adjustable hodkis
Many mods I've done myself piping wiring etc
Aluminum radiator
Rjc 3 1/4 front mount intercooler
Has fan for trans cooler.
70mil turbo with extra heavy center section
5inch Rjc down pipe
Exhaust is stainless custom built
I have all the original eguipment motor with all brackets drive shaft transmission. Everything except wheels exhaust and down pipe. Stock engine went 11.30
This car was originally bought in Mississippi. I'm the third owner. I've maintained this car and had a award winning best paint when it was painted 10 yrs ago.
It always wins shows and is a blast to drive on the street. Car has been to bowling Green several yrs. Never wrecked. I have alot if extra stuff to go with the car I won't need anymore.
Want 30k won't budge. Will post more pics soon.
Cams a comp 224/224
Axel tubes welded
Aluminum radiator
5inch Rjc down pipe
