87 grand national, astro roof, has 103k miles on the body. NO RUST ANY WHERE. Never been in a accident. Every thing works fine, a/c still blows cold.
3k miles on the new turbo
1k miles on the newly rebuilt trans
compression is excellent, 152-155 less than 5 psi deference across all 6 cylinders.
walbro fuel pump
hot wire kit
50lb injectors
new fuel filter
two red Armstrong chips, 93 octane, 108 octane
K&N air filter
custom cold air intake
TE 62 turbo
welded exhaust manifolds
Power Stroke inter cooler
custom 3" inter cooler pipes
1st gen DSM BOV
hempco 65mm upper intake
billet breathers filters
crower valve springs
new neoprene rear main seal
new oil pan gasket
165 deg. thermostat
Billet water neck
custom air to oil, oil cooler
3" thick 2 row All Star performance aluminum radiator
Ram Chargers Duel fans
ATR 3" down pipe
Custom 3" exhaust
summit racing bullet strait through muffler, sounds great, tons of good feed back on the road from people saying that is sounds like a v8 not a v6
3k RPM Orange Stripe torque converter
Vince Janis built transmission, billet servo, wide 2nd gear band, ect. ext.
2 air to oil, trans coolers
trans temp gauge goes with car but not installed, i have no gauge pod for it, the tans pan already has the temp sensor installed, just need a gauge pod and wire it up.
Eaton Posi
31 spline moser forged axles
Boyd coddingtion, Magneto's 17"x8" in front, 17"x10" in rear
BFG radial TA's in the front tons of tread
Nitto drag radials in rear only have ~ 3k miles on them
new brakes
new sensatrac shocks
new heavy duty rear springs
35% tint on all windows but windshield
boost gauge
water temp gauge
center console twin gauge holder
column lock
Alpine CD player
Alpine ipod adapter
kenwood interior speakers
12" sony explode in the trunk
320 watt kenwood amp, powering the interior speakers
760 watt mtx amp powering the sub
I've probably forgot somethings.... I think i got about 8k in modds.
The stock wheels will go with the car also.
the best ET was a 12.60 on the stock trans and converter, car has all the goods to go low 11's. if the weather gets better before i sell it i may take it back to the track.
I'm looking to get 13k obo
motor_city_mechanic@yahoo.com
Evan
walbro fuel pump
hot wire kit
50lb injectors
new fuel filter
K&N air filter
TE 62 turbo
1st gen DSM BOV
new oil pan gasket
165 deg. thermostat
Billet water neck
ATR 3" down pipe
Custom 3" exhaust
Eaton Posi
new brakes
boost gauge
water temp gauge
column lock
Alpine CD player
Alpine ipod adapter
Evan
