'87 GN hard to start when warm
Jim Ayres
:confused: I've been having problems with this car ever since I got it. I've replaced the cam sensor, crank sensor, the esc, plugs, drained old gas out and put in new, even tried a turbo tweak chip instead of the extender extreme chip that came in the car. Also I've tried a different ecm.
The car will start when cold, but after it runs 5 minutes or so and is shut off. if you immediately try to start it , it will just about crank till the battery goes down if you cranked that long. Can the coil pack or ignition module be bad when warm and good when cool? Both of the modules I have checked out good at O'Reilly's and the coil packs check about 12 ohms.
Can anyone help me?
