Im putting some feelers for my limited this is a rust free car with nicely built 109 the new motor has many hp parts extream auto,s 400 turbo with a brake mosier rearend componets XFI fuel management and many other great parts to handle magor hp.pm me for other details. im building alittle something different this yr so this car im going to let go of.The has ran 9,70 at 139,98 the 60,ft was 1,369 leaving with 10 psi rear frame is notched for the larger wheel and also a removable roll bar you can hit the streets with the family in it.Now the 109 is 20 over with a set of 20 over wiseco pistons 6,200 crower connecting rods 3,625 LA billet crank with a few mods to it to fit the the 109 block RJC girdle and oil pan high volume frt timing cover champion alum heads TD roller rockers a NEW. 70 limit eng.GTQ. solid roller this motor has no problem seeing 7000 rpm.I shifted at 6000 on the 9,70 pass im sure it has alot more in it.for the suspension Q,A 1S rear ajd shocks anti roll bar bar 90,10s competion eng.shocks. racing drive shaft and loop.here,s my no.765-744-6115 price 18,987 i will post more new pictures as i take them today under body shoots motor bottom of the doors anything u want to see just let me know.im located in muncie in 47303 765-744-6115.the piture i posted was before i added the suspension parts,:biggrin:
