hrmmm
Well, I had no idea this was here as I have been gone
Well looks like I need to clarify a few things. First of all no one can compare thier 9/11 purchase to their buddies as There are different configs for each application. That is why I take the info I do upon ordering.
The clutch size is bigger than stock and perform very well. I have not heard of any "wearing " the clutch out.
Dave, I love ya buddy but you never had the peice we make at present. Several mods have been made.
Rob, I didnt repair I replaced so I would tend to think you have another problem. REMEMBER, lock up is exhausted meaning if you cannot exhaust fluid fast enough it will unlock. For two converters that I have sold 600 of and you got the two that do not work, I find that real, real odd. However, at any time I still stand behind my word of money back gaurantee in the first year. PERIOD! Send it back.
Now on another note., Ask Jody Bernard. Read this post. Tell me he isn't testing it.
camcojb
Team Member
posted 05-14-2002 12:10 AM
I've got several hundred miles behind the blown motor and the trans works great. The chassis dyno we ran the car on is the type that bolts directly to the axles after removing the rear wheels and tires. We did all the pulls from 3000 rpm with the converter locked. That means full torque through the trans (no tire slippage) and it was making over 700 ft. lbs. at the rear tires by 5500 rpm and climbing, actually shutting off the dyno. Very tough on the trans. I've put a couple hundred street miles on it since the dyno and it works flawlessly.
Jody
( Basically the car is a 69 RS/SS ZL-1 clone. It has a Yenko ZL-1 block with LS-7 crank and rods, Ross blower pistons (ceramic barrier coated), Comp billet roller, Canfield heads, Victor Jr. modified for EFI, Fodge Engineering throttle body, 75# injectors, and Speed Pro (FAST) ECU. I run 2 1/8" Hooker super comps and a 3" "X" pipe and full exhaust. It made 718 hp and 700+ ft. lbs. at the rear wheels at 5500 rpm. This maxed the Dynopack chassis dyno and shut off the runs.
I run a 2004R trans built by Performance Transmissions along with a 2800 stall lock-up 9/11 converter. The trans has the billet input shaft, drum, billet pan and extended pick-up; basically all the bells and whistles except for a transbrake. It has worked flawlessly. Even did all the dyno runs on a dyno that bolts directly to the axles with the converter locked; no problems. The car has an aluminum driveshaft with 1350 yokes and u-joints. There's a 12 bolt with 3.73 gears in the rear.)
As for Mr Wood, I thought if you had a problem, I know you know how to dial the phone. Yes , the converters are produced at TCS and Rusty and I have a special "agreement" . It is our exclusive deal.
There are others coping now, or trying to anyway, ( Who would have guessed), So be sure that the converter you have is in fact one of ours. I am aware that Robs buddies is.
We will be changing the front cover and clutch here shortly to improve even more. We are currently making BILLET front covers and will make the clutch even larger, but this is just to improve the already excellent design. I want the converter to be ours and only ours so I can control quality. We will be selling the new BILLET ones in July if all goes as planned.
So any other questions? I would be glad to answer and Rob, have whoever, call me and I want to get to the bottom of your problem. I still believe you got something else going on but if it proves to be my problem , I always take care of both the problem and the patron.
This converter is one slick piece. There are currently 638 of them out there in use and if this thread is any result of its performance ability I would say it is pretty good. 8% as someone noted with a turbo? That is pretty good my freind.
Locked up it has proven to be a solid reliable piece. Rusty is available at anytime to converse with also. He will give any specifics if needed. But remember, all combos are different and I can move them around to accomidate just about all applications.
I will also add if you do not feel comfortable with my product, do not purchase it. I do not need the headache. But it has proven to be a neat weapon and very well performing product.
