9 sec 86 T type $18995
cruzn57
Still plays with cars!
time has come to sell this,
$18995 firm
cruzn57@yahoo.com
1986 Buick T type, 250 cu in V6- 9 sec sleeper
Everything brand new!
Zimmerman built 109 block (clearanced,bored, align bored,decked, assembled, billet main caps)
RJC- girdle,oil pan, scraper,head gaskets
ARP head studs/main studs
3.625 stroker crank w/ King bearings
K1 rods
billet main caps
Diamond pistons (9to 1 comp)
seal power rings
comp cams special grind solid roller cam .626 lift .242 dur@.050
Danny B cam retention
full shield Comp solid rollers
M&A heads, race ported,flowed, & matched to intake
special nascar springs,retainers,keepers
roller rockers-1.65 ratio
Champion raised port intake,flowed and matched to heads
Earl Brown style front cover, blue printed,clearanced, deburred
ATR stainless steel headers, 4 bolt T4 flange
4in down pipe w/ 4in race muffler
80MM ball bearing Innovative turbo,w/ water to air innercooler, remote tank w/pump
Innovative waste gate, CO2 operated,
150hp Nitrous inj for spool up
95lb inj flowed and matched
FAST BtoB control system w/ data logger
AMS 500 boost control w/co2 controlled waste gate
Bailey 2 step launch control
Lonnie Diers manual T400 trans/ w trans brake,w/3500 stall converter
Turbo Action air/co2 shifter
9 in ford rear, narrowed,
Strange carrier, 35 spline moser axles w/ spool
4 wheel disc brakes
Line lock
narrowed frame rails, gusseted, re-enforced,mini tubbed
adjustable anti roll bar
adj upper control arms
adj lower control arms
adjustable weight jack plates, can adj rear spring pressures independently
fully adjustable rear suspension ( 4 link)
aero motive A1000 fuel pump, & regulator
-10 fuel feed line
-8 return fuel line
dual feed fuel rail
alum fuel cell, trunk mounted- 5 gal
alum water to air reservior, trunk mounted
1500hp water to air intercooler
fiberglass bumpers & alum bumper stands
6 point roll bar w/ swing outs
dual rad fans
Monocoque 15x10 rear wheels w/11.50x28 M/T slicks
Super nice deal especially if it was a package with that trailer. GLWS
BUMP
Yes. but........
I wanted to retain back seat,
so they were installed to allow stock look.
will fit a 13in wide tire!
Sweet car man... Do the swing out bars weaken the cage?? If i ever get a car to go that fast , being a bigger guy swing out bars would be a must!!!.. Any video's of this beast??? GLWS!!!!
we live in So Calif.
but have a house in Kingman,az.
swing out bars make entry and exit ALOT easier for us "well fed" guys.
they are NHRA legal, but I'm sure fixed is stronger,
no vids yet, working out "fast " tunning issues.
Is the car Streetable? Without the slicks obviously.. lol But could I cruise around on a cruise night? The car is sick!
streetable?
yes and no,
it has a 5 gal fuel cell, but I still have orig fuel tank,
inter cooler is Ice cooled, so would need to add ice frequently,
rad has dual fans setup, and works great!
all lights, windows, etc are as built when new. ( work fine)
would it be able to drive to cruises and such ?
heck yea!
yes still available
I've just parked it, and was working on other projects,
car has not been driven, I feel bad for just letting it set,
price was reduced to $17995
thanks for your interest.
I know what you mean, Ive been busy restoring my 85 GN. I wanted a racecar, I wish I could get a loan for this beast!!!
I wish you could too! ( get a loan)
we will be moving soon, so would really prefer to sell it,
thanks
