95% complete roller cam/rocker set up
Otto J
UPDATED
Rockers were sold.
Selling roller cam kit MINUS timing chain
Comp 218-212 Hydraulic roller cam
Comp Roller lifters
Comp 918 Conical springs
Hardended Push rods (for iron heads)
Roller cam button
All that is needed is a new timing set.
Everything in great condition out of a perfectly running 9 second motor.
Reason removed was for a changing the combination.
$500
Everything short of a timing chain
Pic and updated post
Pushrods are 8.200
Rockers were sold. Cam kit still available. Make an offer
Do you have the Comp part number for the Cam? Or is it a custom grind?
Shelf grind
Looks like the 269HR.
Thanks, I was looking at the 264HR. Lemme run the numbers and see if this cam will work with what I'm going to be doing.
Edit: Doh, RPM range runs higher than I'm going to be running. Good luck!
