A bunch of junk I need...
muddin'metal
Factory shifter cable, the clip that holds it onto the bracket at the pan, 3.8 hood badges, trunk badges, trunk interior, 87 Buick grill emblem, Hood pad, rear bumper fillers, Ac hoses, condenser, the door jam vent for drivers door, a decent looking drivers seat (no rips), a factory 200r4 tranny pan, and any other performance junk you think i gotta have...
But the factory shifter cable, clip, and tranny pan I really need!!!!
Thanks, Tyler 256-738-0471
200r4 tranny pan got one for ya. with drain plug which makes servicing tranny alot easier and alot cleaner 120.00 shipped
I have a brand new original shifter cable (installed on car for 1 day, then removed, decided to go with aftermarket shifter), perfect $75.
Let me know if interested...
Thank you,
Claude. :wink:
you can get the cable from the parts stores. Take your old one in and match up the length
So the Clip is the same as a brake line clip. Down side is my local oreilies doesn't stock them. I had to buy a box of 10. I have extra.
I forgot...
I also need a drivers side door jamb switch, the arm held on by two screws below the drivers side door vent in the jamb. And a set of hard heater lines that run from the heater core up the passenger side of the intake, thanks
