Which relay is for the A/C compressor? Also, does the engine need to be running to engage the compressor clutch?
I hooked up my battery and am working on getting rid of the electrical gremlins before firing up the car for the first time. The only thing I have left right now is making sure the AC compressor clutch engages. I jumped the plug on the Accumulator and set the climate control to Max AC. I'm guessing that the ECM still needs to send a signal to the relay to engage the clutch, but I'd at least like to manually trigger the relay if that is the case just to make sure it works. I just don't have any clue which one it is.
