A/C Delete, What Belt to Use
Granny 2
I remember reading that when you put on the A/C delete pulley you must use a different belt. Is this true? If so what do I use?
Part # :confused:
I did the same to my wagon, and looked on gnttype for a part number for a belt, got the belt and it was to long, had to get a shorter one, I will have to look tonite when I get home and I will give you the number tomorow,if you
can wait that long.
Ron
OK I'm back
I don't know if you have a CAR QUEST in your neck of the woods but the part number for my belt was:
K060637 MICRO V BELT
Hope this helps a little. Ohhh also, this was for the S-10 A/C delete bracket.
Ray
Re: OK I'm back
Ray
Thanks Ray, you da man. Found 1 here a mile from where I work and they have 1 in stock. :D
