OK all, i finished up the conversion late yesterday and here is a rundown of what i did and what happened:
Flushed out hoses, lines, and evaporator. Installed New Compressor, Condenser, Drier, Red Orifice Tube. Added oil to compressor, condenser, and drier, 8oz total. Installed green o-rings.
(Orifice tube installs arrow pointing to evaporator, right?)
Vacuumed down system for 30 mins, stopped for 10 mins, vacuumed down again for another hour.
Began the process to add R134A and it took 5 mins for 1 can, can started to ice up. Checked the lower line where the orifice tube is located and it was icing up on the evaporator side. Opened line and removed orifice tube, covered in oil and black trash mostly on small screen side. Flushed out Evap AGAIN with ac flush and air, reinstalled NEW red tube and vacuumed down for 30 mins (while system was opened, i capped off drier with plastic caps originally came with). Tried to add R134a and same thing, lower line of evap icing up in same place.
Ideas on what i did wrong and how to fix this? Very frustrated.
Thanks in advance.
Thanks in advance.
