There was a few threads on this,
Oil cooler line O ring size - package read:10m 15m 2.5. I believe
it means 10mm inside, 2.5 thick.
worked perfect DON'T OVER TIGHTEN!
Oil pump cover - used OEM gasket, cleaned surfaces well and
sprayed both sides of gasket with copper seal
gasket spray. (this stuff is excellent!)
DO NOT OVER TIGHTEN!
I know some others have the same problems, ust thought I'd let everyone know how I solved mine.
