SignUp Now!WOW... 133.9MPH?!? Sure that isnt a 10.17 pass?!?!?
the g-tech meter is it only for performance or like a scanner
The Car Trapped 129.9 Mph at the track with 5-6 Pounds LESS Boost then the Gtech pass , that was with a Huge 1/4 inch by 2 inch crack in the crossover at the v band ..could not launch or spool at all 11.50 was the best it did that day withthe 129.9 Mph ................The Gtech run I left the Line off the gas by just punching it , The car has a trans break but it it just about useless on the street . The Tire is a Hoosier Street slick 28x15x11.50 .....i can see the wrinkle marks on the sidewall afterwards so its dong something.
Id swap housings asap. If you had my turbo you would be trapping 140mph.I ran 9 Psi .....................29PSI Turbo 6776 w .63 housing
Its an old T66BB with a GTQ exhaust wheel. Spool up is good even with the 16 blade 9.5". It goes to 3100 at zero boost/vacuum. A 17 would make it spool like stock with no cat on the street. A journal GTQ sucks unless you have a 3800-4000 stall. I have no complaints. Im still right in the meat of the compressor map until i hit 27-28psi and am over 5700 rpm. The converter works so well at holding the engine down up top it really lays down the mph. Theres a lot more to gain with a good torque converter than the trbos these days. Some guys are still running crappy converters. I think 133-134mph is possible in my combo but its like a grenade with the pin pulled on the stock bottom end. Maybe one more full pass before i retire it if it stays together. Id like to ru n it at 26-27psi and see what it runs. Its getting an S2 soon. Ive got another 9.2:1 stock block one going in my other car with similar parts to what you have. Im probably going to run the T66 on it until i get another turbo. Probably need a 76GTQ/HPQ if i stay 3 bolt. The engine will be good to 6400 with the 224/224 and 885 lifters. I want to run 10.0 at 20-21psi/93 meth.Bison i had a Journal bearing 70GTQ w .85 precision housing on before and i hated it, it was so laggy and not fun at all on the street , im pretty happy the way the car is running now its fast , fun around just cruising , the housing thing is something to try out if i get bored ... So what turbo do you run it lookes like its from the boosted series no , comments Likes /dislikes
