I've had a two gauge pod with a boost/vacuum gauge and a Caspers knock gauge. I am contemplating getting a triple gauge pod so I can add an electronic fuel pressure gauge.
Just finished my gauges. Boost and electronic fuel pressure on the a pillar and oil pressure, water temp, and volts on DNS 3 gauge dash pod. If you were a serious racer you might want EGT, wide band air/fuel ratio, RPM, or knock gauge.
