A-pillers
kilhef
Looking to install some gauges in my GN. Should I install a two or three pod piller and what gauges are the most important to install. Thanks.
I've had a two gauge pod with a boost/vacuum gauge and a Caspers knock gauge. I am contemplating getting a triple gauge pod so I can add an electronic fuel pressure gauge.
Maybe this will help?
Just finished my gauges. Boost and electronic fuel pressure on the a pillar and oil pressure, water temp, and volts on DNS 3 gauge dash pod. If you were a serious racer you might want EGT, wide band air/fuel ratio, RPM, or knock gauge.
I have a 3 pod pillar guage set up. Oil Pressure, Coolant Temp, Vacuum/Boost in that order top to bottom.
Tach, A/F meter, Scanmaster and Alky Control on right side of dash and top of radio bezel.
