If its a stock cam, they are all the same. The ones from John are fine. Also get some new seals. On a roller or larger HYD cam.. you need special springs.
90 lbs on the seat is plenty. Get to high of a spring, you will wipe out the cam. Also dont use the cups with springs that have dampners.
