captndave737
- Feb 14, 2006
I'm a little confused on the wiring. I'm looking at the schematics and it only shows 2 switches; the high pressure cutout switch located in the cooling line near the generator and the pressure cycling switch located on the accumulator dryer. I can't find the other switch that is located in the back of the compressor or how it's wired in.
When I plug in the switch located in the compressor, I think it's an over pressure switch, my cooling fans run continuously and it doesn't matter what position the AC controls are in including off. When I unplug it the cooling fans come on at the 170 deg. programmed in my chip. I have the factory manuals and can't find this switch anywhere!!!
