- May 28, 2001
When I down the ac system, should I flush it before, or after, I put the new parts on, or both?
Any tips on how to do the flush the rite way? [I have a "flush kit"].
Had a compressor failure, and haven't dropped the charge, to look at the orifice screen. So, I have no idea as to what I may find floating around...
Will be replacing everything except the condenser.
So, w/ the system clean/dry, I use 8oz of PAG150, correct?
An interesting bit of info from an ac online thread: When drawing down the system, if the vac pump will only pull 24-26", there will/could be moisture left. Increasing the vac to 27" will greatly enhance the chances of getting that last bit of moisture.....
