What's the point of the high pressure sensor on the back of the compressor? Will the system still function if you install a compressor that doesn't have the sensor, just the burst disc?
Well I found it in my new wiring harness. Not labeled in the diagram but in the compressor plug there are 2 wires that can only be for the high pressure switch, it is just a switch right? Going to be wiring it in later this week.
Yes, it's just a switch. All it does is stop electrical current from going to the clutch when the presure gets to high so you don't destroy the compressor.
