Just checked the AC. It was converted to 134. The pressure on the low side is around 44psi. All I have is one of those off the shelf cans. Seems to be running cool. Since it's hot as hell thought I check the system and put some refrigerant in the system and get it cooler..... I know the 134 is not gonna be as good as the r12 but seems to be working well. Think this is kind a high. Will it damage the system. If it is too high how can I bleed the system? Will the system get warmer if I lower the pressure?
This is measured with the engine running and AC on MAX.
