Accesory Drive bolts
montecarlofast
740 ftlb Rocket Couch
Does anyone have a list of the bolts and studs that go on the front of an 87 GN accessory drive? Pitch Thread and leignth. If anyone has this info it would really help Thanks
most are m10 x 1.5
lengths vary
tensioner bolts to acc bracket 2pc, 25mm
acc bracket bolts to head 50mm
alternator main pivot bolt through tensioner is special part # 25525191
alternator through upper ear bolt 40mm (also needs a nut )
a/c comp bolts long are 120mm 2pc lower left bolt gets a nut , bolt to y bracket doesnt
acc brkt stud through ac compressor special part # 25525502 (also gets a m10x1.5 nut)
ps pump, i never found a listing in any of the manuals for the specs for those two bolts they are m8 1.25 length i believe is 80mm??
get the illustrated manual its all in there
some are listed on gnttype.org
on the 86-87 engine diagram
1986-87 Common parts for Turbo Regals
