TurboWh1
- Aug 12, 2002
They offer both options. Can anyone tell me if the 65mm accepts the stock 2.5" up pipe hose? I know the 70mm is 3" OD. I called Accufab and the person I spoke with could not confirm if they are the same or different. I'm thinking they use the same throttle body housing (3"OD) but the difference is the throttle blade diameter inside.
Also if anyone has feedback on one or the other.... I'm getting to the point where I'm done with the stock throttle body. I don't really want to upgrade but I'm tired of the shaft failure. Ive had 3 stockers fail in 2 years. Basically it creates a vacuum leak/rough idle and or tip in throttle miss condition.
