David Husek
Turbo Buick Performance
- Mar 16, 2007
I can do the machine work on the rods. Having the crankshaft, rods, and rod bearing on hand, I resize the big end of the rods to set correct bearing clearances. The rods get machined for side clearance. Only one rod really needs work for camshaft clearance. If you purchase the pistons and rings from me, I can pin fit the pistons and rods which so often gets overlooked. I can balance also for a drop in assembly. You will need to set main bearing clearances, final hone cylinders and file ring gaps. Usually final main bore size is done in the line hone with bearing and crankshaft on hand to set proper clearance of the main bearings. I have designed the pistons and camshaft in TType6's engine and this would be a excellent starting point as his engine has many similar parts.
I will be starting a 4.1L build very soon also. I have a complete 25,000 mile motor as a starting point. May be built for E85, but not sure yet. Attached are 4.1L stroker pistons....
