I never had an issue with my stock elbow. I could boost all the way up to 25 psi. I never tried higher then that. Now I have a 3" elbow with the Rjc puck. The puck assembly was sticking, so I thought maybe that was part of the problem I put anti seize on it, and it does not stick anymore. I tightened the actuator arm, and with my boost controller off I am now getting just under 15 psi. With it on I can get up to about 20-21 psi, and that is at 75% on the boost controller. When I go to 80% the boost builds up, and then falls to around 15. I also checked to see if the puck was making good contact by taking a thin layer of grease and check the imprint on the turbo. It looks perfect. I might try to boost it with the hose off of the actuator to see if I can get higher boost. What do you think? I am running 110 octane. I'll let off if it goes past 25 or so. Is there any way to tell if I have a HD actuator? I also have a Ta 49 turbo with a Garrett housing. Thanks Dave
