Mike T
- May 3, 2013
Looks really good, Mike. I started on the exhaust ports on mine, but I'm gonna fill my egr ports with aluminum before I go any further.
Thanks for the complement, I'm considering filling these as well. What method are you going to use to melt the aluminum? Maybe you can post some pictures when you do yours.
I've ported a few sets of heads in the past (these are the first Buick heads) so there is still a learning curve. One thing that helps me is to break the porting down into small steps. Do a little and move to the next port and repeat until your satisfied with the shape, this way your not committed and the shape kind of evolves. Another benefit is that if you are using stones by moving from port to port it stays more symmetrical as the stone wears down.
I did make a mistake as it got late yesterday and maybe I could caution you on this. I made mention above about blending the edge of the 60 degree into the pocket a little.....well I ended up getting complacent and removed about 50 % of the 60 degree (not good) so be careful in this area. I think the rule of thumb is about 85 percent throat to valve diameter.
