Adhesive Remover...
aperrego
Drunk? I'll Check. :)
I am finally putting the trim back on and I need to remove some of the adhesive that is out there. Any suggestions? 3m?
I f you can get some laquer thinner that stuff will take off just about anything. Also most body shop supply places carry decal erasers which are basically a rubber wheel you can put on the end of your drill and it will quickly remove sticky adhesives, pinstripes, double sided tape etc.
i would stay a way from using laquer thinner on any paint on the car it can be kind of harsh. the 3m wheels work great for removing decals and double sided tape. if there is any other adhesive residue left on the car either use goo gone, 3m's adhesive remover or wax and grease remover.
