SignUp Now!how easy are they to adjust?I like my QA1-Rs (single adjustable) in the front of my car. even on 0 setting they feel firmer and more stable than the monroes that were in there.
they weight transfer well too.
You turn a knob. That's it. Mine is kinda a pain to reach on one side so I have to use some needle nose pliers to turn it.how easy are they to adjust?
If you get them in properly, you can reach the knobs by finger every time... not sure what is different on one side vs the other Raf?
I can get mine laying down on the side of the car, not even under it.
I have never run mine higher than 3, that was stiff enough for me. The QA1R has a fixed stiff compression setting, with extended rebound settings (up to 90/10)
It sounds like the single adjustable work well. I have seen that they make double adjustable and not shore if its needed for the street and at track.If you get them in properly, you can reach the knobs by finger every time... not sure what is different on one side vs the other Raf?
i was under the impression that the single adj would give me a 90/10 drag race adjustment as well as a street setting.
