You have a few options. T&D roller rockers, or Harland Sharps. Very expensive, though, because you will not only need the rockers assemblies, but you will also need either valve covers or valve cover spacers.
Another viable option is to purchase a set of adjustable push rods. They run approx. $125. They work real well, though, they are a bit of a hastle to adjust on the car. You will need two high quality 3/8" open end wrenches to adjust them. Dont use el-cheapo tools to adjust them, or you might round off the adjusting nuts.
The other option is to use shims between the rocker pedistal and the shaft. This will help you determine the exact cause of the lifter/valvetrain noise. Use a .016", .032" 5/16 AN washers to decrease lifter pre-load. Place them between the shaft and pedistal, and torque them down. Start the engine and see if it improves the valvetrain noise. If it doesn't, install the .032" washers and repeat.
It might be a bad lifter or two. REAL common, with a flat tappet cam. You will have to pull the intake and pull each lifter to verify. If the lifters and cam are in good shape, install adjustable push rods before you install the intake back on. It will make your life MUCH easier to adjust the pushrods. You are shooting for .020-.060" pre-load. You can measure the actual preload with a wire feeler gauge. Slide the small hooked end of the feeler gauge between the retainer clip and the lifter piston. By feel, adjust the push rod to zero lash, then add 3/4 turn. (on adjustable pushrods ONLY) If you buy roller rockers, you adjust them 1/2 turn past zero lash.
I use Smith Bros. pushrods.
Smith Brothers Pushrods Just give them a call, and they'll send them that day. I have a set of adjustable push rods, if you need them. They are used, but in good condition. $65 shipped in the continental US.
Roller rockers are the best way to go, though.
