POINTS TO REMEMBER....
STOCK POWERTRAIN....
while rated at 245bhp, in reality was 280 to 290bhp at 14 psi boost.  using 20% driveline loss yields about 225 to 230whp.  stock wastegate actuator had a fixed rod so 12 to 14 psi boost was typically seen.
stock turbo TB0348 flows 550 cfm and with the stock intercooler is good for about 360bhp, max output for the stock.
the stock fuel pump was rated 110 l/hr (29gal/hr).  stock injectors were rated 29.8 lbs/hr----Bosch 0-280-150-218.  Stock fpr was Bosch 233 regulator...0-280-160-233
GNX
while rated at 276bhp at 15 psi boost, ALL GNX's were dyno tuned to a minimum of 310bhp.  range was 310 low and 380bhp high....tuned with help of adjustable wastegate actuator rod.  Richard Clark has all the GNX dyno records in his files.
made these bhp levels using the same fuel pump, fuel lines, injectors, fpr as the stock turbo regal.
My point is a lot of stuff can be done with stock components.  When time and wear require parts to be changed, obviously consider
complementary coordinating upgrades defined by the advances in tech and availability of parts.
Kirban sells an upgraded pump kit flowing 215 l/hr (57 gal/hr) that is more that adequate for up to 650 HP - about a mid 10-sec ET.  probably like the old walbro 307.  Price is $135
Mike Licht at full throttle speed sells the 255 l/hr (67 gal/hr) pump kit for the same $135.  like the walbro 340, F20000169's, etc.
either pump capacity would be a fine choice for the OP as he already has the fuel pump hot wire kit installed. No changing of the fuel system hard lines with either pump.
the old Bosch blue top 36# injectors 0-280-150-967 would be fine for the OP.
the old Lucas/Tomco "blue tops" at 38# would be fine also.
40# disc injectors are more than adequate.  and a matching TT chip would be and excellent combination.
why spend more $$$ on 60# injectors that won't see anywhere close to 80 percent duty cycle on a stock engine just because Eric can burn a chip for them?
AND anyone should have their basic tune verified before doing any upgrades.  I.E. setting TPS, IAC, check plugs & wires, fuel filter, fresh gas, using Casper's C3I to verify coilpak and ignition module...
http://www.gnttype.org/techarea/maintenance/maintpage.html
sometimes, it is the very basics that are overlooked.
  having a scan tool is a must.  seen way too many folks swapping parts blindly because they do not possess basic scan tools.
So, it's this type of stuff I've offered to review with the OP over the phone.
"EDIT ADD:   And I'm sure there are some talented and knowledeable folks in CA where the OP is located that can help him out, if needed, getting the basic tune worked out and getting a handle on the detonation he's seeing at 12 psi boost."
