SignUp Now!With engines that rotate clockwise (viewed from the front), the car twists up on the drivers side and down on the passenger side. We increase air bag pressure on the right rear to help level the car out at launch. What do you think Robby?robbyc said:well as i grew up in the 60s and 70s and it was common knowledge that the torque reaction twistied the car to the drivers side so the battery was put there on the right to help keep the car from twisting just as there were air bags installed with more pressure in the left bag
DonWG said:Wow! Now that is interesting. What kind of HP increase have you seen with that?
That system sounds like the bomb. Isn't there an aftermarket system available or at least isn't someone modifying the plugs?robbyc said:the factorys develop engines using in combustion chamber pressure sensors to see the combustion process and pressure spikes these could be used maybe with a feed back system
Yes, I suppose you could cut the piston. The flame pattern might be different from bank to bank because of the combustion chamber orientation. It may be difficult to obtain even power output from all cylinders.ijames said:Don, couldn't you take an angled cut across the piston crown to match the bore angle to keep the squish gap constant around the piston? The "coming" knock detection system puts a small test current through the plug gap after the cylinder has fired and measures the residual ionization level to determine if knock occurred. I know Saab is working on this (along with others, I'm sure) but I don't think anyone is ready for production.
