SignUp Now!I once had a copy of Bill Jenkins' book and lost it. Could you post some info on it so I can look around for a copy.
1976. Man, don't that make you feel old. Thanks jjvites.Don,
Sorry it took so long but I just got back in town.
The book is "The Chevrolet Racing Engine" by Bill Jenkins with Larry Schreib circa 1976.
Marty
The comparisons were done at 114 l/c. That seems to be the popular spec everyone prefers, so that's what I used. It does give a very nice compromise between midrange and top end power. I will give it that. In my particular engine setup, the software tells me that the 110 works better at the upper rpm range. Believe me, it does certainly hurt low and midrange, but I am not concerned with that. The juice more than makes up for any tuning shortcomings in the midrange. Since the engine spends the vast majority of its time in the upper rpm range, that is what I concentrated the tuneup on. 6,100 to 7,400 rpm. That is where my engine runs after getting out of the hole and between shifts. The tight T/C causes quite a drop between shifts, but the power band seems to take it in stride quite well. On one run in Vegas where I had mistakingly short shifted 3rd, the rpm really dropped down, but the engine pulled it and I only lost about 2 tenths on that run. I was very happy with the outcome. Actually, that's the run I have posted in the picture and video library on this site.Don,
looking at your can comparision a few posts back did you run the numbers with both cams at 110 l/s and 114 l/s I am curious how that impacted the results. Many computer simulations I have tried run up the HP number as you make the L/S wider with forced induction simulations. What software are you using?
Mike
My current specs:
Duration @ .050
Int. 252
Exh. 260
Lobe lift .420
Lift with 1.7 ratio rocker .714
Lobe separation 110
Intake centerline installed at 5 degrees advance.
Sample specs:
Duration @ .050
Int. 232
Exh. 240
Lobe lift .380
Lift with 1.7 ratio rocker .646
Lobe separation 114
Intake centerline installed at 1 degree advance.
With the smaller cam there is a loss in HP from 22 @ 5000 rpm to 73 @ 7200 rpm.
With the smaller cam there is an increase of 14 HP @ 3500 rpm that increases to 100 @ 4750 rpm.
That's cool. You have the best program for the money. That is a fact.I was looking at the specs in the post looks like the small one is a 100 and installed at 105 and the big one looks like a 114 installed at 113:
I am also suprised at a 122HP swing from one to the other from 4750 to 5000RPM must come on hard there. I love camshaft stuff. I have a copy of EA Pro as well some very interesting things in there![]()
Mike
For a drag application, it's nice to have the HP curve somewhat flatten out for a range of about 1500 rpm. That way you don't have a big drop in HP between shifts.just wondering how much powerband you look for? I know on most engines not turbo but NA the range is aroung 2500rpm. Does the turbo widen this a bit?
Well then I guess it's only going to get worse. I have only just begun.It only got one star because of the long ending![]()
