john saleeby
- Aug 5, 2006
I'm requesting guidance from those who have been through the process. The Goal is a very nice paint job, not show quality where if I receive a rock chip I lose sleep. The car is driven once per week. I live in Southern California. Car has no rust or dents. Looking for a painter. Based on the stated goal here are some questions.
1- After sanding to metal, does Primer need to be used and how many primer coats?
2- Does the windshield, rear glass, side glass, doors, hood, trunk lid bumpers need to be removed for a better finish?
3- What paint brand, (not gonna skimp on materials) is best bang for the buck? Is "German" paint a consideration?
4-- What paint code is closest to stock black color?
5- How many topcoats should be applied and should Sanding occur between the coats?
6- Does lacquer need to be applied and if so how many coats? Is lacquer outlawed in CA?
7- Any special considerations for paint as I want to Ceramic Coat the finished and cured paint?
8- Does Clearcoat need to be applied and, if so, how many coats? Should there be wet sanding between clearcoats?
9- Is the available paint in California solvent based or water based? Does one have a better finish than the other? May be moot if solvent base is not available.
10- How long should paint cure?
Lastly, what qualities should I be looking for in a bodyshop/painter?
Thank you all for your expertise and guidance in this process.
Please PM me or call 626 423 2686
1-
1-
