.060 over?
WIKEDV6,
You said this block is .060" over correct? Now is this 4.060"? Here's why I ask, the standard bore for a 4.1 liter block is 3.965" so if it's 4.060" then it's really .095" over. Even at 4.060" you should be fine. The sleeve isn't a big problem either unless they broke a hole in the wall of the cylinder and hit the water. You might want to have a sonic check done on the block to determine the wall thickness and any core shift.
Good Luck
Neal
BTW, the price sounds pretty fair.
