OneQuikSix
- Jun 7, 2001
I did some preliminary tuning today in the 90deg weather today. I got the car running smoothly at 13-14 psi boost on 93 octane. After several hits to establish a baseline, it looks like the fuel system is way rich (which I expected at lower boost levels). Rich/lean measured by Plx wideband and stock O2 sensor. Afr is low 10.0. Next, I turned on the Alkycontrol kit (knob on 6). At the same boost levels, the AFR goes way lean (14.5). The IAT dropped to the mid 80's. Is it possible the drastic reduction in IAT temps require that much more fuel (kinda like nitrous on a much smaller scale)? Here is what I know...
Fuel pressure rises with boost.
Plenty of voltage from alternator.
Zero knock
It looks like the fuel system is keeping up fine but the tune needs a lot more fuel added to the WOT fueling. Anyone have similar experiences? I see most people have to trim fuel when alky kit activates. I have logs but will have to attach them later.
Zero knock
