87turbot-type
wo2
- Sep 2, 2007
Well I have done a bit of reading on this but not alot, to be honest it doesn't really seem like it is needed for these cars not trying to go lower than 10 flat. Figured I would make a post on some ideas vs what some people have run to get everyones opinions on setups.
1st off
Distributor - Don't really see the reason for this. Seems most stage cars run disty's with high power. Couldn't really find the reason for this and I would think this would be a backwords kind of thinking. We switched to waste spark to increase dwell time to fully saturate the coil before firing. More dwell more consistant spark at higher rpm. I know norbs a member (local to me) has been working on running a stock computer and using a hall effect sensor in the disty to work as his cam sensor for position. (Import style) Most disty setups seem to run fast xfi or some sort of stand alone to achive this. (easier) If someone would like to chime in on the reasoning for going to these extra steps to make something more primitive. Only thing I can think off is to eliminate the crappy module we have stock.
2nd
Aftermarket Boxes/coils
I tried searching for msd and couldn't get much to show up (word being too short) This dis boxes come to mind of what would work on these cars. So has anyone used one with good sucsses? Any issues with module problems after wiring in the box and what coils were used?
I'm just trying to get ideas for later on down the road of fun things to play with and try out on my car. In this case I am thinking that less maybe more and sticking with what it came with maybe the best thing but getting everyones opinons on this topic is also a good way to learn.
I thought I had heard at one point that fullthrottle was working on setting up a coil on plug setup similar to an ls1 engine setup and would think this would be the best possible setup for our cars.
1st off
2nd
