Use a 4.1 Q-Jet manifold. Although it has tapered secondaries incorporated into the manifold, these could be machined. I would use and open carb spacer to at least get some of the effect of a single plane manifold.
You could modify a Q-Jet for blow thru or use a spread bore Holly, or when using a spacer adapt basically any carb.
