Aftermarket Wheel Studs
  • Thread starter Thread starter DEATH4
  • Start date Start date
D
DEATH4
Guest
What size and brand are best for the stock rearend with my combo? Stock studs are a little to short.
Combo: Draglites(15x8), McGard Long Shank Lugnuts, Hoosier QTPs(28x11.5x15);)
You can probably still get the longer metric ones from GM. I would have to try and find the number though.
Dave
Here's the number from Gnttype page #22551491 it says longer than stock (M12 x 1.5 x 76 )
I used the GM #22551491 longer studs for my Draglites...also got some Weld open end shank lugs from Jegs...very nice look...the end of the stud only sticks out the end of the lug enough for the Tech person to see but that part of the stud isn't threaded so it has a clean look...
Stock studs are 1.5" long. If 2" long will work, I got them from Discount auto parts for a buck each specifically for G body and are stock metric thread. GM has open end long shank lugnuts. They are the ones they use that have plastic screw on caps such as GNX lugnuts.
